hej er der nogen der har erfaring med 2 stk hub 3 og hvordan skal de
opsættes .takker
@hl_privat_1958 Hello! I’m not quite clear about the specific aspects you are concerned with when using multiple M3 Hubs simultaneously. You can provide a more detailed description. In the meantime, when using multiple M3 Hubs together in the same local area network (LAN), they will automatically communicate with each other and form a hub cluster without requiring any special action from the user. Once the hub cluster is established, certain automations can be executed at the hub level, without relying on external Internet connections or cloud servers.
Besides acting as a central hub, the M3 Hub also has the capabilities of a Zigbee hub and a Matter controller. When adding and connecting devices to an M3 Hub, you can follow the principle of proximity—Zigbee or Matter devices that are physically close to a particular M3 Hub should be added under that M3 Hub. Each M3 Hub will then manage the nearby devices independently, operating in a distributed manner.
Hi, I guess you are talking about Hub M3, and wanna to set them up? It is better if you can connect them to Aqara home app via the same network, which means connect to the same WiFi or wired connect to the same router. If so they Hub M3 can communicate with each other and set up a local cluster
