Ultimate Guide to Seamless HomeKit Integration with Aqara Devices - Even Without an Apple!
Hey everyone! I’m fairly new to the smart home world but went down the rabbit hole with Aqara devices a couple months back. I don’t own any Apple stuff (Android gang here), but I was dying to try out the simplicity and automation goodness everyone raves about with HomeKit. Long story short, I pulled it off — no iPhone, no iPad, no Mac. Yep, it’s possible, and it works great once you tweak a few things.
Here’s my setup:
  • Android phone
  • Aqara G3 hub (super clutch — supports HomeKit)
  • Home Assistant running on a Raspberry Pi
  • Friend who lent me their old iPad during initial setup (pro tip!)
So what I did was:
  1. Used the iPad just long enough to set up the HomeKit code via Aqara Home app and connect everything.
  2. Once devices were added to HomeKit on that iPad, I linked them using Home Assistant’s HomeKit Controller integration — this bridges the devices over without needing Apple gear afterward.
  3. From there, I control everything via Home Assistant on Android — automations, notifications, camera feeds, all of it.
It’s wild how smooth it runs once it’s up. I only needed the iPad once and I haven’t touched it since. You could probably use an emulator too, but I haven’t tested that route.
Anyone else gone the “non-Apple HomeKit” route with Aqara? Drop your setup below or ask away — I’ll try to help. Would love to hear any better shortcuts too!
@HomeAutomatorPro It’s fantastic to hear about your successful setup with Aqara devices and HomeKit without relying on Apple products! Your creative approach of using a borrowed iPad just for the initial setup and then leveraging Home Assistant’s HomeKit Controller integration is truly impressive. This method is a great way to enjoy the benefits of HomeKit while sticking with Android.
Your setup with an Android phone, Aqara G3 hub, and Home Assistant on a Raspberry Pi is quite savvy. The Aqara G3 hub indeed supports HomeKit, making it a crucial part of your configuration. By connecting your devices via the Aqara Home app initially and then bridging them with Home Assistant, you’ve found a seamless solution that suits your needs.
While the reference information doesn’t directly cover using HomeKit without Apple devices, your story adds valuable insight into how flexible smart home setups can be. It’s a great reminder of the power of community and shared knowledge. I encourage others to share their experiences or inquire about different setups—there’s always more to learn and explore in the world of smart home automation. Thank you for sharing your journey, and I look forward to hearing more innovative solutions from our community!
Hi! Are are you bringing the camera into Home Assistant? Once it’s added to HomeKit it can’t be added to Home Assistant.
