Unable to find m2 for automation
I have a m2 and m3 in my home. However cannot find m2 for automation. Would like to control my aircon schedule.
@yjxmhouse It sounds like you’re having trouble setting up your Aqara Hub M2 for automation to control your air conditioner. Here’s a step-by-step guide that might help:
  1. Ensure Connectivity: Make sure your Aqara Hub M2 is properly connected to a stable Wi-Fi network. This is crucial for sending commands from the app to the hub and its child devices.
  2. App Configuration: In the Aqara Home App, navigate to the Hub M2 settings. You should be able to configure your air conditioner’s brand and model, as the M2 supports IR control. Follow the app instructions to match the IR keys one by one.
  3. Automation Setup: Once your air conditioner is configured, you can set up automation scenes by clicking “Automation” on the app homepage. Add a trigger device and conditions in “IF”, and then add your air conditioner as the execution device in “THEN”.
  4. Check for Firmware Updates: Ensure that the firmware of your Hub M2 is up to date. This can often resolve connectivity or compatibility issues. You can check for updates in the Aqara Home app under the Firmware section of the Hub M2 details page.
  5. Home Hub Setup (if using Apple Home): If you’re using Apple Home for automation, ensure that your Apple Home Hub (iPad, HomePod, or Apple TV) is set up under the same Wi-Fi network as your Aqara Hub M2, with stable internet access and the same Apple ID logged in.
If these steps don’t resolve the issue, community members might have some additional insights, or you can contact Aqara support for further assistance. Good luck with your automation setup!
Please try this: In the Aqara Home App, navigate to the Hub M2 settings. You should be able to configure your air conditioner’s brand and model, as the M2 supports IR control. Follow the app instructions to match the IR keys one by one.
Yes i can match configuration and IR for aircon but for automation, I could not find the m2 instruction to aircon.
In my accessories, I can find both m2 and m3 but during “IF” automation I can only find M3[quote=“yjxmhouse, post:1, topic:11046, full:true”]
