Underfloor heating Control on Aquara - which baterry - powered thermostat with dry contact?
Hi,
I need help selecting an Aqara thermostat for underfloor heating.
I have an Aqara M3 gateway and I’m looking for an Aqara thermostat that:
is fully compatible with it,
is battery-powered,
has a “dry contact” output – a voltage-free contact that works like a regular on/off switch that doesn’t provide its own voltage but rather closes/opens the control circuit (closed circuit = on, open = off).
I want to use this thermostat to control underfloor heating using this type of dry contact.
Does anyone:
use a specific Aqara model in this configuration?
Can they confirm that this model works with the M3 gateway and has dry contacts?
Or do they have a proven wiring diagram for connecting underfloor heating to this thermostat?
I would appreciate any suggestions and specific models that this works with.
Thanks!
@marcin_porebski You seem to be experiencing an issue with selecting an Aqara battery-powered thermostat with dry contact output compatible with the M3 gateway for underfloor heating. You can contact customer support for assistance.
Contact the Aqara Home App Customer Service Team (Home > Help & Feedback > Customer Service) or scan the QR code:
