Understanding Device Naming in Smart Home Systems
As I began setting up my smart home, I quickly noticed that each device had both a Name and a Label field. While the Label seemed straightforward—it’s what appears in apps and controls—I was puzzled about the purpose of the Name field. Why have two fields? Where is the Name used, and what’s the best way to name them?
Initially, I assumed the Name was just a technical identifier, but I wanted to make sure. I started experimenting by changing the Name and Label fields for different devices. For instance, when I added a fan controller, it was initially labeled as “Dimmer Switch.” I changed the Name to “Office Fan” and selected a different Device Type Handler (DTH). This made me realize that the Name field might be used internally by the system or specific integrations.
Through some research and trial, I discovered that the Label is indeed what users interact with daily, while the Name often serves as a more permanent or technical identifier, especially when integrating with third-party apps or scripts. For example, if I’m using a script to control devices via the REST API, the Name might be referenced there.
To keep things organized, I’ve developed a simple naming convention:
  • Name: Use a short, technical name (e.g., “OfficeFan”)
  • Label: Use a descriptive, user-friendly name (e.g., “Office Ceiling Fan”)
This way, both fields serve their purposes without confusion. I also noticed that when adding devices through the mobile app, the Label updates automatically, but the Name stays as the default unless changed manually.
A small story: I integrated a new smart speaker and forgot to set the Name field. Later, when troubleshooting an automation script, I realized the script was referencing the default Name, which didn’t match my expectations. This taught me the importance of consistently naming devices from the start.
If you’re like me and find yourself wondering about the best practices for naming devices, I’d love to hear your tips and experiences! Let’s share how we organize our smart homes for clarity and efficiency.
