Hey everyone, I’ve been diving into Home Assistant and exploring how to create more sophisticated automations. I stumbled upon the concept of using event_data in event-triggered automations, and I wanted to share my journey and insights with you all. Hopefully, this will help others who are also learning about this topic!
The Journey of Discovery
I started by observing events through the developer tools, filtering by * to catch all events. For example, when my door sensor changes state, I see an event like this:
“event_type”: “state_changed”,
“data”: {
“entity_id”: “binary_sensor.door_bathroom”,
“old_state”: {
“state”: “off”
“new_state”: {
“state”: “on”
At first glance, this data seemed a bit overwhelming. I wanted to trigger an automation when the door sensor changes to on, but my initial attempts didn’t work as expected. Here’s what I tried:
yaml
alias: bathroom_light_via_doorsensor
trigger:
- platform: event
event_type: state_changed
event_data:
entity_id: binary_sensor.door_bathroom
new_state:
state: “on”
action:
service: light.turn_on
entity_id: light.bathroom
This didn’t trigger, so I started questioning why. Why wasn’t the automation working even though the event data seemed correct? I realized I needed a better understanding of what event_data actually contains and how it can be used effectively.
Key Insights
After some research and experimentation, here’s what I learned:
- Event Data Structure: The
event_datain Home Assistant events contains theentity_id,old_state, andnew_stateof the entity that changed. To trigger an automation based on a state change, you need to reference thenew_statewithin theevent_data. - Filtering by State: To trigger an automation only when the door sensor is
on, you need to include thenew_statein your trigger configuration. Here’s how I adjusted my automation:
yaml
trigger:
- platform: event
event_data:
new_state:
state: “on”
action:
- Verification Tools: Using the developer tools to inspect events and the state machine helped me understand what data was available and how it could be used. I recommend exploring these tools if you’re also learning about event-driven automations.
Questions and Reflections
While I managed to get my automation working, I still have some questions:
- Event Data Visibility: Is there a more user-friendly way to view and analyze event data within the Home Assistant interface? I often find myself digging through logs or using developer tools, which can be time-consuming.
- Best Practices: What are the best practices for structuring event-driven automations? Should I always use
new_statewhen triggering on state changes, or are there scenarios whereold_stateis more appropriate?
Conclusion
This journey taught me a lot about how events and state changes work in Home Assistant. It’s a powerful system once you understand how to tap into its capabilities. I’m excited to continue exploring and creating more sophisticated automations!
If anyone has additional insights, tips, or experiences to share, I’d love to hear them. Let’s continue learning together and make our smart homes even smarter! ![]()
