Hi everyone! I wanted to share my journey of developing Zigbee device handlers (DTHs) and some insights I’ve gained along the way. If you’re new to Zigbee or looking to dive deeper, this might be helpful!
The Challenge
One of the biggest hurdles I faced was deciphering the documentation. It’s scattered all over the place, and the existing primer wasn’t clear enough. I decided to break it down step by step to make it more manageable.
Getting Started
First, familiarize yourself with the SmartThings IDE. Pairing a device is straightforward—just press the button or follow the manufacturer’s sequence. The IDE will show you the device’s details, including clusters and attributes.
Understanding the Data
When a device joins the network, it sends a ‘zbjoin’ event. This message contains crucial information like the device’s manufacturer, model, and clusters. Here’s a simplified breakdown of what each part means:
- Endpoint: Each endpoint represents a different function of the device (e.g., plug, switch).
- Cluster: A group of related attributes and commands (e.g., on/off, temperature).
- Attribute: Specific data points within a cluster (e.g., current temperature).
Key Operations
There are four main operations you’ll perform with Zigbee:
- Configure Reporting: Set how often the device reports changes.
- Read Attributes: Query the device for specific values.
- Write Attributes: Send commands to control the device.
- Send Commands: Execute actions like turning on/off.
Development Tips
- Use
zigbee.configureReporting()to set up monitoring without overwhelming the network. - For non-reportable attributes, use
zigbee.readAttribute()periodically. - When writing attributes, consider manufacturer-specific codes to handle variations across devices.
- Debugging is essential. Use
log.debugto track values and messages, but remember to disable it once done.
Fingerprinting
Once your handler is ready, create a fingerprint so the device automatically uses it upon joining. This involves specifying the profile ID, inClusters, outClusters, manufacturer, model, and a friendly name.
Example Project
I developed a handler for the Xiaomi Zigbee Smart Outlet (ZNCZ02LM). It’s not perfect, but it’s a solid starting point. You can find it here.
Conclusion
I hope this guide saves you some time and frustration. If you found it useful, consider buying me a coffee to keep the coding going! ![]()
Cheers,
Cristian
