Unlocking the Potential of Motion Sensors in Multi-room Setups
Hey all, just wanted to share what I’ve figured out fiddling with motion sensors in a multi-room setup. I’ve been toying around with this for a few months now and I think I’ve finally hit a sweet spot — figured someone here might find it useful or maybe even have ideas to improve it.
Started off simple, just one sensor near the hallway to trigger the lights. But then I thought, what if I could chain a bunch of them across rooms to create more intuitive automations? Like actual room-by-room awareness.
So here’s what I did: I placed Aqara motion sensors in the living room, hallway, and kitchen. Instead of each working independently, I used Home Assistant to build a sort of “presence tracker”. If motion is detected in the hallway after someone was in the living room, and then soon after in the kitchen — boom — it knows you’re moving through the house. This cascades lighting, adjusts the thermostat as you move, even kicks up the air purifier if needed.
What surprised me is how NATURAL it feels now. No need for manual triggering or apps — it just works. The trick was dialing in the timeouts and knowing where to place the sensors so they don’t interfere with each other or trigger false positives (had to ban my cat from one room lol).
Anyone else running a setup like this? Or using motion sensors in creative ways? Curious how others avoid the “lights randomly turn off while I’m still here” problem, especially when you’re just chilling and not moving much.
Keen to hear your setups or pain points. This stuff’s addictive once it starts working right!
@DoorBellDude Thank you for sharing your innovative approach to using Aqara motion sensors in a multi-room setup! Your method of creating a “presence tracker” with Home Assistant to intuitively manage lighting and other home automations across rooms is truly inspiring.
By strategically placing sensors in the living room, hallway, and kitchen, and linking them for a seamless transition from one room to another, you’ve effectively enhanced the natural feel of your smart home environment. Your experience with adjusting the timeouts and sensor placements to avoid interference, like preventing false positives from your cat, is a valuable insight for anyone looking to optimize their setup.
For those encountering the issue of lights turning off unexpectedly, integrating a system that detects subtle movements or using sensors with higher sensitivity might help. Additionally, ensuring the motion detection intervals and placement are fine-tuned can significantly reduce these inconveniences.
Your setup sounds both efficient and user-friendly, and it’s fantastic to see how much joy it brings you! I encourage others to share their experiences or any creative uses of motion sensors they have discovered. This kind of community sharing is what makes smart home technology so exciting and evolving. Keep up the great work, and feel free to update us on any new tweaks or discoveries!
