Hey folks,
Just wanted to share some real-world tidbits from my recent experience setting up Aqara devices with Apple Home. I’m an automation enthusiast but no coding wizard, so hopefully this helps someone in the same boat.
First off—yes, Aqara and HomeKit can play very nicely together. The trick? It’s all about clean pairing and keeping things simple. I started with the Aqara Hub M2. Added it to HomeKit first via the Home App (scanned the QR code), then started building the accessory list from there.
One thing I learned the hard way: make sure your HomeKit network is solid. I had some sensors randomly going offline until I realized my HomePod Mini was on a 5GHz network while everything else was on 2.4GHz. Once I got them all on the same frequency, stability jumped big time.
Also, if you’ve got automation triggers acting weird (like motion sensors not firing scenes), check the Aqara app settings, not just HomeKit. Some automation logic behaves differently depending on where you configure it.
Anyway, if you’re trying to unlock full control with Aqara + Apple, my hot take is: keep it native when possible. Use Apple’s Home app for the basics, but let the Aqara app handle the extra smarts (like sensitivity settings or time-based triggers). It’s been buttery smooth since I tuned it right.
Curious to hear what kind of setups others are running. Anyone doing more advanced stuff with NFC tags or Siri Shortcuts?
Share your hacks ![]()
