Hey all,
So I’ve been playing around with motion sensor setups for a few weeks now and thought I’d share some “aha” moments in case anyone’s in the same boat as I was — kinda overwhelmed but excited AF.
First off, I’m not a total noob, but definitely not a guru either. Just your average smart home nerd trying not to annoy the rest of the household with lights turning on at weird times. ![]()
What finally clicked for me was setting zones and tweaking delays. Like, instead of just “motion = light on,” I now have layers. For example, motion in the hallway only triggers the light if the lux level is below 10 AND someone hasn’t walked through in the last 2 minutes. Crazy difference. No more lights popping on just because the cat sneezed.
Also — BIG ONE — overlapping sensors. I used to just toss a motion sensor in the room and call it a day. Now I’m using two per room, one angled low (to ignore small pets) and one up top for human movement. Totally changed the game.
Bonus tip: using the Aqara app alone is fine, but pairing it with Home Assistant or Node-RED opens up a whole new level. If you’ve ever wanted your lights to fade in only when it’s between 7–9PM and someone walks into the room while holding a taco… you can probably do it.
Curious what setups you all have running. Anyone else go a little too far with the motion automations? Drop your best weird-but-useful routines!
