Updates via Apple home and thread feature parity
I own a number of aqara devices. While the products are reliable, I am frustrated by the lack of feature parity with thread. In addition I need the aqara app to get firmware updates.
Is this something that aqara will be looking in to? I have no interest in running zigbee as matter over thread is the future which is what my smart home is being built on.
Hi. What you’re describing, getting firmware updates directly through your ecosystem like Apple Home instead of a manufacturer’s app, is actually a core pillar of the Matter standard.
Here is a bit of background on how this works technically:
  • Matter OTA Updates: The Matter specification explicitly provides for Over-the-Air (OTA) software updates.
  • The Role of the DCL: The Connectivity Standards Alliance (CSA) uses the Distributed Compliance Ledger (DCL) for this. Think of it as a public directory where manufacturers host links to their firmware files and security checksums. This allows Apple Home, Home Assistant, and others to know exactly where to find the official, secure update.
  • Aqara & DCL: Aqara has already started populating this database for several of their models.
How to check for yourself: You can use the official DCL Explorer to see if Aqara has already provided firmware for your specific devices:
  1. Go to: Distributed Compliance Ledger
  2. Search for Vendor ID 4447 (this is the ID for Aqara/Lumi United).
  3. Click on a model to expand it. Under ‘Software Versions’, you can see which versions have been officially released for the Matter update path.
If Apple Home isn’t offering the update yet even though it’s listed there, it’s usually due to Apple’s specific implementation of the rollout. However, the system definitely works: I have already successfully updated Aqara devices via Home Assistant using this exact method. It’s likely only a matter of time before Apple fully streamlines this experience.
A note on Feature Parity: Regarding your frustration with feature parity, it is important to remember that Matter is still a very young standard. Many features are currently in development, and some advanced functions are not even fully defined in the standard yet. While Zigbee has matured over many years, Matter over Thread is still catching up. A great example of this gap is the configuration of device-specific hardware parameters. For these types of “pro” settings, users are currently still forced to use the manufacturer’s own app or bridge, as the Matter standard simply hasn’t created the data fields for them yet.
I am having trouble with T1 temperature and humidity sensor, failing offline I have the Aqara doorbell camera 410 hub.
[Uploading: IMG_6253.png…]
Hello. From the FAQ:
Why is the Aqara Temperature and Humidity Sensor T1 offline often?
Possible reasons:
  1. The accessory is too far away from the Hub, please try to install the accessory closer to the Hub.
  2. Low battery or dead battery. Please replace the battery.
  3. The accessory is installed on the metal surface and the signal is interfered. Please avoid metal surface.
Thank you for that info.
I have verifed the battery is good and I do believe it is a range issue however it is only about 30 feet from the Hub.
I am currently using it in a freezer and interferance could be the issue it will work for about an hour or 2 and then fail offline.
I will try to move the hub closer to the unit and see if that will fix the issue.
/r
giblet
Is it on or in the freezer?
If the sensor is in the freezer, there will be several problems:
  1. The temperature is not optimal, which makes it difficult for the battery to maintain its voltage.
  2. The freezer acts like a metal cage, significantly reducing reception. Poor reception will also put greater strain on the battery as it struggles to maintain a connection.
  3. Jumidity and condensation pose a major risk. Every time the door is opened, warm, moist air enters and condenses on the cold sensor. Since most standard sensors are not vacuum-sealed, this moisture can lead to frost formation inside the housing, potentially causing short circuits or long-term corrosion of the electronic components.
Yes, it is in a Freezer.
The reason it is in the freezer is to monitor the temperature and humidity of the freezer. The temperature range of the sensor is within the range of a freezer.
I do understand the issues with the frost on the circuitry. To mitigate the frost issue, it is placed on the door lid of the freezer vice the bottom or wall of the freezer.
The metal of the freezer makes sense that it would cause interference, however when it is receiving it shows excellent signal strength and the battery is 100%.
Even if the device is rated for this temperature range, the battery remains a significant weak link. Low temperatures drastically slow down the chemical reactions inside the cell, which creates high internal resistance. Consequently, the voltage may appear stable while the sensor is idle, only to “cliff-dive” toward 0% the moment the device draws power to transmit a data packet.
Please don’t be fooled by an “Excellent” signal status. While Zigbee waves can often pass through the rubber door gasket (which doesn’t shield as metal does), the app may only display the last successful signal strength. This “cached” value can show a perfect connection even if the sensor has already dropped offline, only updating once the system eventually triggers a timeout.
Lastly, while placing the sensor on the door lid helps with signal transmission, it is also the primary entry point for warm air. This creates a constant freeze-thaw condensation cycle on the electronics every time the freezer is opened. Over time, this moisture ingress is likely to lead to corrosion or internal short circuits, regardless of the sensor’s temperature rating.
I also use the sensor outdoors. However, the conditions there are not quite so cold. Not for such long periods of time, at least. Nevertheless, I have put the sensor in a waterproof box. You can buy boxes like this very cheaply on eBay.
