I recently embarked on a journey to upgrade my Ideal Independent C24 boiler to OpenTherm, and I’m thrilled to share my experience with you! Many professionals and even some forums suggested that this model wasn’t compatible with OpenTherm, but I was determined to explore this possibility further. After reaching out to the manufacturer, I discovered that it is indeed compatible, but there were a few key components I needed to source.
First, I purchased an OpenTherm harness kit, but I quickly realized that wasn’t the only piece I needed. I also had to invest in a weather compensation kit. This kit provided the essential cables required for the OpenTherm setup, which I wouldn’t have had otherwise. It’s important to note that you won’t need an outdoor sensor with OpenTherm, so that’s one less item to worry about!
The installation process was surprisingly straightforward. I connected the power and Tado to the boiler, making sure everything was securely in place. The new harness kit made this step especially easy. I also had to disconnect a timer, which was a minor inconvenience but necessary for the setup.
Once everything was connected, I set up the Tado app for OpenTherm. The app was user-friendly, and within no time, my boiler was fully integrated. I’ve been using this setup for a few weeks now, and it’s been nothing short of amazing. The heating is more efficient, and controlling everything through the Tado app has added a whole new level of convenience to my home.
If you’re considering upgrading your boiler to OpenTherm, I highly recommend giving it a try. It’s a bit of a project, but the results are well worth the effort. Let me know if you have any questions or need advice along the way!
