Using LIFX Scenes in Aqara
Is there a way to use a scene created in the LIFX app in Aqara?
@thesilvafamily Thanks for reaching out with your question about integrating LIFX scenes into Aqara. Currently, the reference information provided does not mention direct integration of LIFX scenes with the Aqara Home app. However, you can explore using automation platforms that support both LIFX and Aqara devices as a potential workaround.
We encourage you to share your experiences or solutions within the community, as other users might have found innovative ways to achieve this integration. If you have more questions or need further assistance, feel free to ask!
At the moment, LIFX scenes created in the LIFX app cannot be directly imported or used in the Aqara app. The two ecosystems—LIFX and Aqara—are separate and do not natively share scene configurations.
However, there are a few possible workarounds, depending on your setup and goals, for example,
:wrench: How to Use Aqara Scenes with LIFX via Matter & Home Assistant
:white_check_mark: Step 1: Enable Aqara’s Advanced Matter Bridging
With the Aqara Hub M3, M100, G5 Pro, M2, M1S…, Aqara now supports Advanced Matter Bridging, which allows not just devices but also Aqara scenes, signals, to appear in other Matter ecosystems — like Home Assistant (via Matter controller like SkyConnect or built-in).
Result: Your Aqara scenes will show up in Home Assistant as triggerable scenes (e.g. scene.good_night).
:white_check_mark: Step 2: Add LIFX to Home Assistant
• Add your LIFX account via the official LIFX integration in Home Assistant.
• All LIFX bulbs and groups will become available as entities (light.bedroom_lamp, etc.).
:white_check_mark: Step 3: Create a Unified Home Assistant Scene or Automation
In Home Assistant:
• Create a Scene or Automation that:
Triggers your bridged Aqara scene
Sets LIFX lights to your desired color/brightness (or calls a LIFX scene if recreated)
Thanks! I’m going to try that.
