Hey everyone, I wanted to share my experience with using the Pi-hole V6 REST API to implement some dynamic network management features. I’ve been using Pi-hole for quite some time now, and it’s been a fantastic tool for managing ads and unwanted traffic on my network. However, I recently wanted to take it a step further by integrating it with my Home Assistant setup to automate certain network controls based on specific conditions.
The Goal
My primary objective was to create a system where I could temporarily disable Pi-hole’s blocking functionality for a set period. This would be particularly useful in scenarios where I want to allow certain traffic temporarily, such as during specific times of the day or when certain devices connect to the network. The idea was to automate this process without manual intervention, ensuring seamless operation.
The Setup
I started by exploring the Pi-hole V6 API documentation, which was quite comprehensive. I realized that I could leverage the REST API to authenticate, disable blocking, and then re-enable it after a set time. Here’s a breakdown of how I approached it:
Authentication: The first step was to authenticate with the Pi-hole API. I set up a service in Home Assistant to handle the POST request for authentication, capturing the session ID which would be required for subsequent API calls.
Disabling Blocking: Once authenticated, I used another service to send a POST request to disable the blocking feature. I included a timer parameter to specify how long the blocking should remain disabled. In my case, I chose 5 minutes as a test duration.
Re-enabling Blocking: After the specified time, I needed to ensure that the blocking feature was re-enabled automatically. This was achieved by setting up an automation that triggers after the timer expires, sending a DELETE request to log out the session and restoring the default blocking state.
Challenges and Solutions
While setting this up, I encountered a few challenges:
Session Management: Maintaining the session ID was crucial, especially since it changes with each authentication. I found that storing the session ID in a variable and using it in subsequent calls was the most reliable method.
State Checking: Ensuring that the API calls only execute when necessary was another consideration. I implemented checks to verify the status of the blocking feature before executing any commands, preventing unnecessary API calls and potential errors.
Automation Timing: Timing the automation correctly was essential to prevent any overlaps or gaps in the blocking functionality. I tested different intervals and settled on a 5-minute window to ensure smooth operation.
Results
The implementation was a success! I now have a fully automated system that temporarily disables Pi-hole’s blocking feature for exactly 5 minutes, then re-enables it seamlessly. This has been particularly useful for testing network configurations or allowing specific traffic without manual intervention.
Tips for Others
If you’re looking to integrate Pi-hole with your Home Assistant setup, here are a few tips:
Understand the API: Spend time familiarizing yourself with the Pi-hole API endpoints and their functionalities. This will help you design your integrations more effectively.
Use Variables for Session Management: Storing session IDs and other dynamic data in variables can simplify your automations and reduce errors.
Test Thoroughly: Before deploying any automation, test it extensively to ensure it behaves as expected under all conditions.
Log and Monitor: Implement logging for your API calls and automations. This will help you troubleshoot any issues that arise and provide insights into the system’s operation.
Conclusion
Integrating Pi-hole with Home Assistant via the REST API has been a rewarding experience. It not only enhances the functionality of my network but also adds a layer of automation that makes managing it much more efficient. If you’re looking to take your network management to the next level, I highly recommend exploring the Pi-hole API and how it can be integrated into your smart home setup.
Happy automating! ![]()
