Using Third-Party Matter Devices in Aqara Home? Share Your Experience!
Hi, has the situation changed? Are most matter devices still not supported in Mainland China?
@AqaraOfficial @Peng I have exposed my old Tado V3 Radiator valves using matter bridge ( Home assistant) works Fine, can run automation.
Further Testing :wink: will do in winter.
  • Temperature sensor :white_check_mark:
  • Humidity Sensor :white_check_mark:
  • Child Lock ( :white_check_mark:)
  • Temperature Control :white_check_mark:
  • Window open Detection :white_check_mark:
  • Battery status ( Not available)
MatterWithAqaraHome
I have a Chinese M3 and I am not able to add Tapo P110M via Matter. Is said “Access to this Matter device is not currently supported” when I am attempting to pair it.
Is there a diff in Chinese M3 compare to international version?
More interestingly, I found that adding Tapo P304M to M3 do not have any issue.
