Vera's Reliability in Commercial Installations
I’ve been exploring the use of Vera devices for commercial home automation projects, and I wanted to share my experiences and thoughts with the community. While many discussions suggest Vera might not be robust enough for professional setups, my personal experience has been quite positive.
Once configured, Vera devices have proven to be very reliable. Sure, the user interface isn’t the most intuitive, and adding new devices can sometimes be a bit tricky, but the stability once everything is set up is impressive. I’ve successfully integrated Vera with various Z-Wave devices, and the system has performed consistently without major issues.
I’ve also looked into alternatives like the Fibaro HC2, which is often recommended for commercial use. However, from what I’ve seen in forums, the HC2 can have its own set of problems, such as devices dropping offline, which doesn’t seem to be as much of an issue with Vera. Plus, Vera supports a wider range of devices, including door locks and remote AC controls, which is a big advantage for comprehensive home automation.
So, my question to the community is: what are the reasons Vera might not be considered suitable for commercial installations? I’d love to hear other perspectives and experiences. If anyone has successfully used Vera in a commercial setting or has insights into its limitations, I’d appreciate sharing that knowledge.
In the meantime, I’ll continue experimenting with Vera and documenting my findings. It would be great to see more discussions on how Vera can be optimized for professional use, perhaps through custom configurations or integration with other systems.
Looking forward to your thoughts and experiences!
