Hey everyone, I’ve been diving into the world of IoT data visualization with Home Assistant, and it’s been an absolute blast! If you’re curious about how to make the most of your smart home data, I’d love to share some insights and tips that might help you get started or take your setup to the next level. ![]()
First off, I stumbled upon this fantastic feature where you can export data from your Home Assistant instance using SQLite. It’s like unlocking a treasure trove of information about your home’s behavior! I’ve been using this to track everything from temperature trends to device usage patterns. For example, I set up a query to monitor the temperature of a nearby river using the Swiss Hydrological Data sensor—it’s been a fun way to stay connected with my environment. ![]()
One thing I’ve learned is that while the built-in history component is great, it’s limited to daily visualizations. But fear not! With a bit of SQL magic, you can drill down into specific entities or time periods. I’ve even exported the data to CSV and used LibreOffice Calc and matplotlib to create some pretty slick graphs. If you’re into Python, matplotlib is a lifesaver for generating custom visualizations. Here’s a quick example of how you can pull data from your Home Assistant database:
python
import sqlite3
from matplotlib import dates
import matplotlib.pyplot as plt
conn = sqlite3.connect(‘/home/ha/.homeassistant/home-assistant_v2.db’)
data = conn.execute(“SELECT state, last_changed FROM states WHERE entity_id = ‘sensor.aare’”)
timestamps =
values =
for x in data:
timestamps.append(dates.date2num(dt.parse_datetime(x[1])))
values.append(float(x[0]))
plt.plot_date(x=timestamps, y=values, fmt=“r-”)
plt.ylabel(‘Temperature’)
plt.xlabel(‘Time line’)
plt.savefig(‘sensor.png’)
This little script generates a temperature graph that’s perfect for monitoring environmental changes or even just keeping an eye on your home’s climate. The best part? You can tweak the SQL query to focus on any entity or time frame you like. ![]()
If you’re more of a spreadsheet person, exporting the data to CSV and using tools like LibreOffice Calc or Google Sheets is another great way to visualize trends. I’ve even shared some of my graphs with the community, and it’s been awesome to see how others are using their data creatively. ![]()
I’d love to hear from you all! How do you visualize your IoT data? Do you have any favorite tools or techniques that you’d like to share? Whether it’s a custom script, a clever use of spreadsheets, or even just a cool way to present your data, let’s keep the ideas flowing! ![]()
Happy visualizing, and here’s to making the most of our smart homes! ![]()
