I have W100 Climate Sensor, conected to M200 hub via Thread communication protocol. FW version is 1.0.1.0. Checking the Temperature/Humidity values on the Aqara Home app, I notices, looking into W100’s Logs, that I can see that the Temperature is updated regularly (if change is at least 0.5 degree Celsius or after 1 hour; this is according specification, I believe). However, humidity is stucked on yesterday’s value… Why there is no update for humidity (humidness in the Logs)?
Maybe the change is too small for an update. You can try changing the W100 sampling settings to custom. In custom mode, you can select periodic sampling and reporting so you get regular updates
I don’t see any possibility to change the sampling setting. I think this is feasible only when using Zigbee as communication protocol on W100. When using Thread there is no such option (but then you have e.g. additional switch options on the W100 device which is not supported with Zigbee)
Oh, right, I’m using Zigbee mode and forgot to check if it’s also available with Thread
I notice that I can’t get the temperature on the W100,only the humidity,Why do you think this is?
