I just installed a W200 and updated to the latest firmware. I’m not getting the humidity reading or sensor in HomeKit but it is showing in the Aqara app. I tried a full factory reset and still not showing up. I posted this in Reddit and someone shared a screenshot that showed humidity in the W200 exposed to HomeKit. Anything I can do to get this functionality? Don’t want to put another redundant sensor in that room. I first installed the W200, connected it to my M3 hub, then connected to HomeKit in the Aqara app.
Do you see the W200’s humidity as a separate tile in Apple Home, or inside the thermostat’s detail screen? I’d check inside the thermostat first.
In Apple Home app tap on the Room the Thermostat is assigned to. At the top of that page you should see “Temperature” & “Humidity”. Tap Humidity and it should be the Thermostats Humidity sensor.
