W200 Minimum compressor outdoor working temperature settings and aux heat settings
Right now the minimum compressor working temperature you can set on the thermostat is 20 degrees and the aux heat outdoor temperature is 50 degrees. My heat pump unit is ok to run to -10 degrees outside, and I definitely don’t want the aux heat to be able to come on when it’s 50 degrees.
I have returned the W200 and gone back to my ecobee for now because the current settings would make the aux heat run too much and increase my power bill. I’m hoping Aqara will update the settings to allow a much lower compressor outdoor temperature setting and lower aux heat outdoor temp setting.
I’m aware of the current work around of changing the aux heat run with heat pump setting to off, but I would rather just continue using my ecobee until there are lower temperature options for these 2 settings.
I agree. Those two settings must have a wider range.
Has the range been increased? My compressor runs as low as 5°F, and while I love Aqara products, I can’t buy the W200 thermostat if it doesn’t support a wider range.
Please don’t make me add another vendor to my home’s ecosystem!
