Hi all, recently acquired 2 W200’s, a W100 and a T7H T1…loving them so far but have an issue with trying to use a preset mode and an alternate data source. Heating system is natural gas boiler with 2 zones (Taco valve control board).
Desire is to have the W200 use the W100 temperature (which is paired directly to the W200 via Zigbee but is NOT connected to the thermostat…want to use the buttons for HA automations) as the target at night to better control the bedroom temp. The W200 is in a hallway and the W100 is in the bedroom.
In the Aqara app I am able to go to the W200, select Set Data Source and in the Manually Choose Device(s) section select the W100 and it instantly changes the actual temp reading on the W200 as well as in HA…this is verified because the bedroom temp is 2 degrees cooler and as you switch between the W200 and the W100 as the source, the temp changes.
I then went to Preset Modes, selected Sleep and used Set Data Source to select the W100, I enabled Schedule Management and then created 2 schedule entries to turn on Sleep at 9p and turn on Home at 8a.
When sleep mode activates, the temp reading does not change to the W100 temp…all of the screens indicate the W100 is selected but the temp change confirmed in the manual process does not occur when the sleep preset is activate. I confirmed the screen showed the Sleep mode was active and I also manually selected schedules but the temp stays on the W200 device reading. I also tried this same process with a virtual sensor (2 - 3rd party sensors averaging) and noticed the same behavior…the W200 never changed to the other temp reading.
Has anyone come across this…known bug perhaps or am I missing a step? Any other ideas as to tests I could run to validate? As I mentioned above, making this change in manual mode works perfectly, I just have to do that every evening and change it back in the morning.
Thanks in advance for any help. I have found some other interesting things in testing the W100 in Matter/Thread vs Zigbee but will make separate post for that. Very cool items…!
The manual switch changing both the W200 and Home Assistant readings suggests the W100 link is working. Since the saved source fails with both the W100 and a virtual sensor, the preset applying that source seems like the narrower failure point. Could you capture the W200 reading and selected source immediately before and after activating Sleep manually, along with the W200 firmware and Aqara Home version? That would make a useful reproducible report without re-pairing first.
I meant to include versions in original post…thanks for asking.
W200: 4.5.70_0004
W100: 0.0.0_1641
Aqara Home: 6.4.4
I will grab some screen pics later today and post.
Here is a shot from HA of the W200 for last 24 hours just to show it works fantastically well setting it manually. You can see around 9p when I make the switch how the temp reading drops about 2 degrees as I switch it from itself to the W100. Then on the far right (this morning around 11a) you can see it jump back up when I switch back to itself as the data source. Pretty cool…
Here are several examples w/pics, hopefully I grabbed what you were asking for @jamesfengyuyang
Manual selection of This device and the W200 reading (74F)
Manual selection of W100 and the W200 reading (73F)
Newly created preset named DMJ01 with W100 set as data source (tried this to see if a new preset worked…it did not) and the W200 in DMJ01 mode - note the W200 at 74F (incorrect, should be 73)
Home Preset with this device set as data source and the W200 in Home mode - note the W200 at 74 (correct)
Your comparison makes the failure much clearer: manual W100 selection changes the W200 reading from 74°F to 73°F, while the new DMJ01 preset still shows 74°F despite listing W100 as its source. That points to the preset applying its saved source as the next thing to investigate; it doesn’t yet establish a firmware cause. I would send these steps and screenshots to Aqara support with the versions you posted (W200 4.5.70_0004, Aqara Home 6.4.4), and ask whether activating a preset is supposed to override the current manual source.
Support ticket submiited - thank you for your comments.
