W200 Screensaver not consistently coming on
I just installed a W200, which replaced my base ECOBEE. I have the screensaver set to “Always on” and the screensaver timer set to 15s. Screen Activation Distance is set to the middle. Firmware is updated. Once the 15s passes the screen just goes to black.
I have tried restarting through the device, through the app, and even pulled the faceplate to let it reset. The screensaver was finally working yesterday but this morning when I woke up it was no longer coming up. I also noticed yesterday once instead of displaying the screensaver I chose there was a screen showing what looked like stars moving across the screen.
What am I missing or is this a buggy device?
@davemarzilli welcome to the forum! I have the same settings.
I also have Wake-up screen settings to Enter Screensaver
I will occasionally see the shooting stars that you mentioned but it doesn’t happen often.
Intersting. I am assuming yours goes to the screensaver reliably?
It does, except during the Sleep Mode window (I assume).
Well, looks like mines is displaying correct after being at work all day. I will keep an eye on it and see if it acts up again like it did this morning.
Follow-up to share a mea culpa that might help someone else. I don’t know if there was an initial problem where the screen saver was not coming on but once I went through several posts trouble shooting the settings I did get it to work correctly. The next morning it was acting up again, which spurred my original post. Turns out the reason for it not coming on was the “Sleep Mode” which turns it off at night. I get up earlier than it was set to come off Sleep Mode which made me think it was acting up, when in fact it was working properly. Additionally a shooting starts screen saver comes on occasionally which seems to just be part of the program to avoid burn-in.
Overall very happy with the thermostat. The Adaptive Temperature through HomeKit seems to be working very well for my family. With the irregular coming and going it is nice to have it automatically adjust when people are home and not home. I will be interested to see how it goes during the summer, but I hope the same. I may need to get a remote temp sensor since the thermostat is downstairs and the bedrooms are upstairs. It tends to get a pretty big temp differential in cooling between the two floors.
Anyway, thanks for the help all!
That’s great! Glad it all worked out. You could just adjust your sleep time on the thermostat and never have that problem again. And yes, the shooting stars show up occasionally. But they’re kinda cool.
