Water Flow Sensor Integration and Bathroom Automation
Hey everyone, I’m really excited to share my recent project with you! I’ve been working on integrating a Z-Wave water flow sensor into my home automation setup, and it’s been a fascinating journey. The goal was to automate the exhaust fan in each bathroom based on water usage, which I thought would be a great way to enhance comfort and energy efficiency.
First, I wanted to give you a quick overview of my setup. I have a PEX water distribution panel in my house, with each bathroom, faucet, and shower having its own home run. I decided to install a water flow sensor on each shower’s home run. The idea is that when the sensor detects water flow, it triggers the exhaust fan in that bathroom to turn on and stay on for about 30 minutes after the water is turned off. This should help with moisture control and improve air quality.
However, finding the right water flow sensor that fits my budget was a bit of a challenge. I went through several options and did a lot of research before settling on a solution. I was really hoping to find something that didn’t cost too much, but it seems like quality sensors can be quite pricey. If anyone has any recommendations or has found a good deal, I’d love to hear about it!
Once I got the sensors installed, I started working on the automation part. I set up rules in my home automation system to monitor the water flow and control the exhaust fans accordingly. It’s been working pretty well so far, but I did run into a few hiccups along the way. For example, I had to tweak the timing to make sure the fan doesn’t turn off too early or stay on unnecessarily. It’s all about finding that perfect balance!
I’m really happy with how this project has turned out. It’s not just about the technology; it’s about how it improves my daily life. Being able to automate something as simple as turning on a fan based on water usage feels like a small victory, but it adds up to a more comfortable home environment.
I’d love to hear from anyone who has tried something similar or has tips for improving this setup. Maybe there’s a more efficient way to handle the timing or a different sensor that works better. Let’s keep the conversation going!
Thanks for reading, and happy automating! :slight_smile:
