Waterproof window sensor
I’m looking for a window sensor to be used inside my shower as waterproof as possible. With HomeKit support
@GostFlash Thank you for reaching out with your query! While Aqara offers a variety of Door and Window Sensors that support HomeKit, it’s important to highlight that these sensors are designed for indoor use only and are not recommended for humid environments or outdoor use. This means they may not be ideally suited for placement inside a shower.
If you’re seeking a sensor with HomeKit compatibility that can withstand wet conditions, you might want to explore other options specifically designed for such environments. Meanwhile, engaging with the community for personal experiences or alternative recommendations could be beneficial. Your input is valuable, and we are always eager to enhance our offerings. Keep the ideas coming!
Would it get wet outside the shower? I don’t know of any waterproof ones, but Aqara sensors work very well.
I’ve got the aqara sensor on the outside of my shower door which triggers music automations with home assistant.
I have seen people use 3d printed enclosures and also flex seal on aqara products before so that may be your most affordable option
