What are the most important settings to configure after installing a smart lock?
I’ve been looking into the best practices for setting up and using a smart lock, especially for people who are new to smart home security.
Most users start by registering fingerprints or setting a PIN code, but there are several other things worth considering:
Managing administrator and family member access
Removing unused fingerprints or access codes
Understanding battery warnings and emergency unlocking
Configuring notifications and access history, if supported
Connecting the lock to a smart home ecosystem
Reviewing remote access and security settings
I came across this Vietnamese guide about using smart locks:
I’m particularly interested in how Aqara smart lock owners manage access for family members and occasional guests.
What settings do you recommend configuring immediately after installation, and have you encountered any common mistakes that new users should avoid?
@mattervietnam Hi there! :wave: Thanks for sharing such a thoughtful and comprehensive overview of smart lock best practices. It’s great to see new users diving into the nuances of home security management—this kind of proactive setup really pays off in the long run! :house::closed_lock_with_key:
To answer your specific question about managing access for family members and guests on Aqara smart locks, here are a few key settings and tips based on common user experiences:
1. Managing Family & Member Permissions
Setting up the right hierarchy is crucial for security and convenience.
  • Admin vs. Member: When you first add the lock, the initial user becomes the Admin. Admins have full control, including adding other admins or ordinary members.
  • Inviting Family: You can invite family members (like a spouse) via the Aqara Home App. Go to Home Management, select your home, and invite the user. You can assign them as a Member or Admin.
  • Security Device Authentication: For sensitive devices like door locks and cameras, you may need to authenticate the user specifically to ensure they have the correct permissions. Once you’ve entered the details, just confirm and send the invitation.
2. Fingerprint Registration Best Practices
Since you mentioned fingerprints, here are some pro-tips to avoid registration failures, which is a common hurdle for new users:
  • Dry & Intact: Ensure the finger is dry and the fingerprint isn’t damaged or worn out.
  • Multiple Angles: When registering, you’ll need to press the finger 7 times. Try to change the angle slightly with each press rather than repeating the same spot, as this improves recognition accuracy.
  • Recommendation: The thumb is often recommended for the best unlocking experience.
  • Methods: You can register fingerprints via the Aqara Home App prompts or by using the physical Set button on the lock’s back panel (after enabling Local Settings in the app)[“content”:2].
3. Battery & Emergency Access
  • Battery Indicator: Keep an eye on the LED indicator. A Red light means low battery or charging is needed, while a Green light indicates a full charge.
  • Alarms: The lock will alert you to various issues like unclosed doors, low battery, or repeated verification failures, ensuring you stay informed about the lock’s status.
4. Connecting to Your Ecosystem
  • Hub Connection: After adding the lock, it will automatically try to connect to available hubs in your account. Note that the effective range is about 10m, but walls can affect this.
  • HomeKit: iOS users can also connect via Apple Home by scanning the HomeKit code found on the lock’s back cover or manual.
It sounds like you’re already on the right track by thinking about notifications and access history! Managing these settings early helps prevent those “oops” moments later.
If you run into any specific issues with permissions or device connectivity that aren’t covered here, feel free to reach out to the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code below for more efficient support:
Have you tried setting up a guest PIN yet, or are you sticking to fingerprints for now? We’d love to hear your experience!
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully.
