The installation methods of the Camera Hub G3 are as follows:
- The packaging box of this product does not contain a bracket. But does support a 1/4-inch threaded screw. If wall mounting or lifting is required, the bracket or any other threaded screw-compatible mount shall be purchased separately.
- Please ensure that the camera is successfully added to the APP before mounting on the wall. Install the Micro SD card when the device is powered off.
- The camera can be placed on a writing desk, dining room table, bookcase, coffee table or other horizontal surfaces.
- After mounting the camera in the lifting position, the image needs to be flipped in the Aqara Home app to be viewed normally.
Note:
- The camera should be placed within the range of wireless Wi-Fi signal coverage.
- Do not place it near a strong electromagnetic interference source.
- Avoid a direct light source to camera lens at close range.
- Make sure there are no obstructions around the device.
- This product is only for indoor use.
@Teresa_Z Ah, the versatile Camera Hub G3! You’ve certainly covered the essentials of its installation methods. Here’s a quick recap to affirm your points and sprinkle a bit of tech-savvy flair:
Threaded Screw Support: While the packaging might not have a bracket, the Camera Hub G3 is ready to mingle with any 1/4-inch threaded screw mount you fancy. Want to show off your wall-mounting skills or perhaps create an aerial view? Just grab a compatible bracket and you’re set!
App First, Then Mount: A gentle reminder from Aqara to ensure your camera is cozy in the app before committing to a more permanent spot on the wall. And remember, the Micro SD card is a bit camera-shy, so insert it when the device is off.
Flat Surface Friendly: Whether it’s chilling on a desk, blending in on a bookcase, or gracing your coffee table, the G3 is quite the adaptable guest for any horizontal surface.
Image Orientation: If you’re going for that high perch, don’t forget to flip the image in the Aqara Home app so you don’t end up viewing the world upside down. A small step for you, a giant leap for viewing clarity!
Installation Tips:
- Keep within Wi-Fi’s warm embrace.
- Steer clear of pesky electromagnetic interferers.
- Avoid blinding the lens with direct light.
- Ensure a clear view with no obstructions.
- Definitely keep it indoors—no adventures in the great outdoors for this one!
Your setup guide is spot-on and incredibly helpful for anyone diving into the world of smart home setups. Keep sharing these gems with the community!
