I started a Home Assistant automation journey a couple months ago, and looking for some inspiration on automations that use presence sensor.
I currently have the FP300 in the bathroom for a simple light turn on/off, and for a humidity automation that turns on the physical switch for the bathroom fan when it detects humidity. It then waits 10 minutes after humidity drops to normal levels before turning the fan off again.
Love not having to flip that switch!
What are some of your favorite presence sensors from Aqara and what are your favorite automations to go with them?
For me, the FP300 is also a great device! I use it already in most of my rooms! The FP2 / FP400 is great for leaving room to get more options! Let’s see if the FP400 can bring there more possibilities for me
Same here. A mix of FP300, FP2 and now also a FP400. Being battery-powered the FP300 is very flexible bite I love the zones the FP2 and FP400 offer. They open the door to much more interesting automations
The FP400 is my favorite in Home Assistant because its presence signal does more than switch a light. In my setup, it controls Philips Hue lighting and can stop the TV, music or radio when I get up. I also use presence for climate automations. My air conditioner is controlled through an API, so I can adjust its settings and airflow direction.
Your fan timer made me think about retriggering. If humidity rises again during the ten minutes after it first drops, I would restart that countdown rather than let the fan switch off during a second shower. I would keep that reset independent of the light’s timeout. Does your current automation already handle a new humidity rise during the countdown?
my favorite is the FP400 in our living room. One automation I use every day is simple but works really well:
When the FP400 reports occupancy, Home Assistant checks the illuminance from the same sensor. Only if it’s below 60 lux does it turn on the sofa light. When the room is empty, the automation waits two more minutes before switching the light off. On top of that, the FP400 itself has an absence delay of 180 seconds, so the light never goes off while someone is just sitting still on the sofa.
yaml
alias: Living room motion light
mode: restart
triggers:
- trigger: state
entity_id: binary_sensor.living_room_fp400_occupancy
to: "on"
conditions:
- condition: numeric_state
entity_id: sensor.living_room_fp400_illuminance
below: 60
actions:
- action: light.turn_on
target:
entity_id: light.sofa_light
- wait_for_trigger:
- trigger: state
to: "off"
for: "00:02:00"
- action: light.turn_off
target:
Mode restart matters here. If someone comes back during those two minutes, the automation starts over and the light stays on.
Using the built-in light sensor is the part I like most. You don’t need a separate sensor, and the light doesn’t switch on during the day for no reason.
I placed FP300 sensors in every room for all the usual automations but one day it hit me like a ton of bricks. I shouldn’t have to scroll, swipe or navigate threw all these devices to get to what I need in the room I’m in.
It was navigation Armageddon when all I wanted to do was tap on/off something real quick or check the status of something.
I decided to create a “Presence” dashboard in Home Assistant. I added 21 individual rooms to the dashboard with all the controls to everything. (wall switches, wall plugins, lights bulbs, ceiling fans, heating/cooling, TV’s, surround systems, Door Locks, all sensors etc).
Each time I enter a room the controls automatically display on my iPhone screen allowing me to control everything in the room without having to navigate the app looking for controls. At the bottom of each page is an icon I can tap to jump into the full area/room controls if It’s needed.
As I leave one room the controls disappear and the new room I entered appear.
There is no delay and it’s surprising how well it works. bluetooth tracking used to be the standard but the FP300 is so much easier and more reliable + offers additional sensors with no wires.
@ralphdaub welcome to the forum!!!
I use a FP400 in our master bedroom. When our system is in HOME mode, the main bedroom light is turned on. If our system is in NIGHT mode, then our two bedside lights give off a dim red glow when either of us gets out of bed so we can see where we’re going at 3 in the morning.
I have an FP2 for monitoring my small open-plan living, dining and kitchen area, mainly for lighting automation.
I also use an FP300 in the shower area to monitor humidity (for air vent automation, along with a vibration sensor stuck on my dryer to control the vent as well) and presence detection for three light switches. Also the presence detection will let me know if someone in the bathroom by changing my standing light colour to red in my living room area.
@starlitter the dim red glow at night is a great idea. Red light is much easier on the eyes when you’re half asleep. Do you use a separate zone for each side of the bed so only the light on that side comes on, or does the whole room count as one zone?
That’s one thing I like most about the FP400: in my living room, the sofa zone switches the sofa light, and the rest of the room doesn’t react at all.
Well, that’s possible but I just have a box (the bed) inside a box (bedroom). The lamps are on both sides of the bed and are red at 30% brightness, so quite dim. I wouldn’t want to get around my side of the bed with my light on only to trip on my wife’s side on my way to pee. So both lamps on works just fine. And this automation is only allowed when my system is in Night mode. Home mode turns on the bright ceiling light.
Makes sense, and the night mode condition is the key part. I do something similar in the living room: the sofa light only reacts to presence when the illuminance from the FP400 is below 60 lux, so during the day nothing happens at all. Red at 30 percent sounds like a good value, I might try that for our hallway.
