What should guest mode pause in an Aqara lighting setup?
A guest should not need to learn the house’s sensor rules to keep a room comfortable. For an Aqara lighting setup, I would give guest mode a narrow job: pause automatic shutoff and scheduled brightness changes in the occupied guest room while keeping ordinary wall-switch control predictable.
The part I would decide before building it is how the mode ends. A fixed overnight timeout could surprise someone sleeping late; an explicit “resume normal lighting” control is clearer, provided the household can see that guest mode is still active. Hallway night lighting could stay on its usual rules, so one bedroom exception does not disable the whole house.
This is a design proposal rather than a tested recipe for a particular controller. If you have built a guest mode, which lighting rules did you pause, and how do you prevent the exception being forgotten after the visit?
I use a “Kill Switch” or I guess you could call it “Guest Mode”.
When the kill switch is active a specific bulb breaths/pulses Purple as a reminder. Guest mode is also announced on a centrally located speaker.
It turns the effected area back to the defaults (aka:dumb).
When the Kill Switch is turned off it’s announced “Automations are now active” on the same speaker and the reminder light bulb turns off. (and I feel better)
If you need a guest mode (for whatever reason) embrace it 100%. It’s temporary anyway.
You’re either pregnant or you’re not.
There is no half way, it confuses people.
I use a guest mode virtual switch in my smart home. It acts as a condition for most automations, so if guest mode is on things do or don’t run appropriately. Mainly I use this for babysitters so that when we leave the house it doesn’t go into full away mode closing garages, locking door, shutting off lights and adjusting thermostats.
The purple indicator and spoken status make the override hard to forget—that’s the missing piece in my sketch. I’d keep the off switch easy to reach and have it restore normal rules without replaying any missed scheduled changes.
The part I overlooked and still need to address is the depth of the “Guest Mode” or how it’s split up. Do you cover the entire home or do you separate out sections or rooms or levels?
I tried levels upper/lower and fails to meet all the needs so it was deleted
I tried rooms (18 total) and fails to meet all the needs and confused people.
I’m stuck on one Guest Mode at the moment that seems to work but covers everything inside.
I did implement a Presence Dashboard that tracks you within the home even when “Guest Mode” is on.
As you move around the Home the iPhone screen will automatically display the room controls.
I would keep one visible house-wide Guest Mode switch, then let each automation decide whether to honor it. That avoids an 18-room control panel while allowing essential lighting and safety rules to stay independent. If one switch is still too broad, splitting by behavior (lighting versus away mode) may be easier to explain than splitting by floor.
