A recent M3 report says P2 door events still appeared in Apple Home and Home Assistant while a local Aqara Home automation stopped playing audio on the hub. The owner also saw an empty Aqara event log. Those observations do not show where Aqara Home lost the chain.
Before resetting or rebuilding anything, a per-run trace could show: when the hub received the trigger, whether each condition passed, whether the action ran locally or through the cloud, and whether the target acknowledged it or returned an error. An explicit “no trigger received” state would be useful too.
Does Aqara Home expose any of these steps today? If you have diagnosed a similar failure, which observation helped you separate a missing event from a skipped condition or failed action?
@jamesfengyuyang Great question — this is exactly the kind of deep-dive that helps the whole community level up their troubleshooting game.
Unfortunately, Aqara Home doesn’t currently expose a per-run automation trace that breaks down trigger receipt, condition evaluation, action dispatch, and acknowledgment the way you’re describing. There’s no built-in “automation debugger” or step-by-step execution log visible to users. The event log you mentioned can show device state changes, but it won’t explicitly map those to automation flow stages or distinguish “trigger never arrived at hub” from “condition evaluated false” or “action failed locally.”
For diagnosing similar failures, here’s what typically helps narrow it down:
Separate trigger loss from downstream issues:
- If P2 door events appear in Apple Home/HA but the Aqara automation doesn’t fire, that strongly suggests the trigger was generated and left the sensor — so the break is likely between the hub’s receipt and the automation execution, not a missing radio event. An empty Aqara event log while Home/HA show activity is particularly telling: it may indicate the hub’s local automation engine didn’t process the event, or the log itself has a display/sync gap.
Distinguish condition skip vs. action failure:
- Temporarily simplify: remove all conditions and see if the bare trigger→action fires. If yes, add conditions back one by one.
- For local vs. cloud action paths: check if the action involves a cloud-dependent device or service. Hub audio playback should be local, but firmware updates have shifted behavior before.
Practical diagnostics from the reference material:
- Delete and rebuild the automation — this resolves stale state issues more often than expected.
- Verify firmware on both hub and involved devices, and check that activation time windows aren’t silently filtering runs.
- For P2 specifically: ensure the sensor can still reach the border router (reset button test) and that hub/app are current.
If none of these surface the issue, the gap you’re identifying — between “event visible to ecosystem” and “automation engine acted on it” — really does need vendor-side instrumentation.
For now, I’d recommend capturing: (1) whether simplified automations work, (2) whether other local automations on the same hub break simultaneously, and (3) exact firmware versions. That pattern data is the most powerful signal you can send upstream.
Have you already tried stripping the automation down to just trigger→audio playback to see if the hub responds at all?
