Hi everyone,
I am planning to pair the Doorbell Camera G400 (wired) with an Aqara S1 Plus and I would like to hear your experience.
- Does the S1 Plus work well as the hub for the G400, or is a newer hub (M200/M3) clearly better?
- Any recommended placement and settings so the doorbell chime and notifications are fast and reliable?
- Which automations do you use with the two together (unlock the door, lights, announcements)?
Any recommendations are welcome. Thanks!
@pablobarros80 Hi there!
Great questions. It’s always exciting to dive into setting up a smart doorbell ecosystem. Let’s break down your queries based on the official Aqara documentation.
1. Hub Compatibility: S1 Plus vs. Newer Hubs
The good news is that the Aqara Smart Video Doorbell G400 is a Wi-Fi-based device that connects directly to your home network. It does not require a dedicated Aqara smart home hub (like the M2, M1S, or S1 Plus) to pair or function for basic features like video and chime repeater connectivity.
However, if you want to integrate the G400 into broader automations (like triggering lights or scenes), the Aqara Panel Hub S1 Plus is fully compatible and can act as the central controller for these routines. You don’t need an M200 or M3 specifically for the G400 to work, but the S1 Plus is a solid choice if you already have it or want a panel interface. Note that newer hubs like the G410 act as Matter Controllers/Thread Border Routers, which offers different integration benefits, but for standard Wi-Fi doorbell automation, the S1 Plus works well.
2. Placement and Settings for Reliability
For the best performance with notifications and chime reliability:
- Wi-Fi Signal: Install the doorbell close to your wireless router if possible. The G400 supports dual-band 2.4/5GHz Wi-Fi 6, but signal strength is crucial. Keep the distance within 15m, ideally with no more than one wall (≤24cm thick) between the doorbell and the router.
- Chime Repeater: The system includes an indoor chime repeater that acts as a bridge. Ensure this is placed where it has good Wi-Fi connectivity to relay notifications reliably.
- Installation Height: For optimal viewing angles and minimal blind spots, install the doorbell 1.3–1.4 meters from the ground to the top edge.
3. Recommended Automations
With the Panel Hub S1 Plus, you can create some really cool routines. Here are two popular setups:
- Secure Welcome Home Routine: When the Video Doorbell G400 is triggered, the Panel Hub S1 Plus screen can automatically display the live video feed. This lets you see and respond to visitors instantly without picking up your phone.
- Evening Relaxation: You can tie the doorbell into scene settings. For example, if you trigger a “Night” scene, the hub can dim living room lights, adjust shades, and turn on air purifiers, creating a cozy atmosphere after you’ve checked the doorbell.
This information comes from community discussions and user experience summaries and may vary by environment. Please verify carefully. [Source: Aqara Support Docs]
Hope this helps you set up your system! Feel free to share your own automation ideas once you get it running.
This will be more efficient. If you do not have an Aqara Home account, “Please
click here” to create a ticket.
