Hi everyone!
I was lucky enough to get the new Aqara Floor Lamp T1 through the exclusive trial, and I wanted to share a slightly different way of using it.
When you think of a floor lamp, you probably imagine something standing upright in a corner, right?
Well, who says it has to stand at all? ![]()
A different idea
I wanted to add some indirect lighting to a small area with a bench and a large mirror above it. But I also wanted to keep everything as clean and minimal as possible, without another lamp visibly taking up space.
So instead of standing the Floor Lamp T1 upright, I placed it horizontally along the bottom of the wall, hidden behind the bench, with the light pointing upwards.
And I really like the result!
The light spreads across the wall, creating a soft, almost floating effect behind the bench. The lamp itself is barely visible, and that’s exactly what I was going for.
Installation & first impressions
The physical setup for this idea is surprisingly simple. No drilling, no wall mounting, just positioning the lamp where I wanted it and connecting the power.
What I particularly like is how much difference such a simple light source makes. The indirect illumination adds depth to the space without making it feel cluttered.
The photos show the setup from different angles, using a simple white light.
One little detail I still want to improve is the cable management. The power adapter is visible from certain angles, so there’s still some room for improvement.
Smart lighting without overcomplicating things
Of course, the T1 offers much more than just white light, including different colors and smart lighting possibilities.
But sometimes less is more.
For this particular spot, I actually prefer a simple, clean white glow. It fits the minimal look I’m going for, while leaving room to experiment with scenes and automations later.
Final thoughts
I think the Aqara Floor Lamp T1 is an interesting example of how a product doesn’t necessarily have to be used in the most obvious way.
Sometimes a different placement is all it takes to turn a regular lighting product into something that feels much more integrated into the room.
And apparently, a floor lamp can look pretty good without ever standing up!
Thanks to Aqara for the opportunity to try it through the community trial.
I’m curious: has anyone else tried using the T1 horizontally, or found another unusual place for it?
