Hey everyone, I wanted to share my recent experience with setting up a WS2811 LED strip in my daughter’s room. It was a fun project, but I ran into a bit of a snag with the first three LEDs not behaving as expected. I thought I’d document my journey in case anyone else runs into similar issues.
First off, the setup seemed straightforward. I purchased a 5m WS2811 strip, connected it to my Raspberry Pi, and used Home Assistant to control it. Everything worked perfectly except for those first three LEDs. They would flicker randomly and wouldn’t turn off when the rest of the strip did. It was pretty frustrating, especially since it’s in my daughter’s room and I wanted it to be seamless for her.
After some research, I realized that the WS2811 chips control groups of three LEDs. If one chip goes out, it can affect the entire group. I tried cutting off the first three LEDs, thinking maybe the IC was dead, but the problem persisted. That’s when I decided to look into the wiring and power supply more closely.
I discovered that while the rest of the strip was working fine, the first three LEDs were receiving a slightly different voltage due to the way the power was being distributed. I added a small capacitor to stabilize the voltage and made sure the ground connections were solid. Lo and behold, the flickering stopped, and the LEDs now turn off properly when the strip is switched off.
For anyone else dealing with similar issues, I’d recommend checking your power supply and ensuring that the ground connections are secure. Also, if you’re using multiple segments, consider adding a small capacitor to each segment to stabilize the voltage. It’s a small fix, but it makes a world of difference!
This experience taught me the importance of thorough wiring checks and the value of community forums for troubleshooting. It’s amazing how a little tweak can turn a frustrating project into a successful one. Happy tinkering everyone! ![]()
