Wyze Cam Duplicate Videos: A User's Experience and Solution
Hey everyone, I wanted to share my experience with the Wyze Cam app and how I managed to resolve an issue that was initially quite puzzling. I’ve been using Wyze Cams for a while now, and they’ve been a great addition to my smart home setup. However, recently I noticed something odd with the video uploads. Here’s what happened:
I have both a Wyze Cam and a motion sensor set up in my backyard. The system worked perfectly for months, but suddenly, I started getting duplicate videos whenever motion was detected. It was a bit frustrating because it seemed unnecessary and wasted storage space. I quickly realized that if both the camera and the sensor detected motion at the exact same time, the app would upload the same video twice. That was the first issue.
The second issue was a bit more concerning. If the camera and sensor detected motion at different times, only the most recent video would be saved. This meant I was missing out on some important footage, especially if there was a sequence of events. I wanted both videos to be available for review, so I knew I had to figure out a solution.
What I Tried:
  1. Adjusting Settings: I went into the app and tinkered with the motion sensitivity settings. Lowering the sensitivity slightly helped reduce the number of duplicate uploads but didn’t eliminate them entirely.
  2. Checking Firmware: I made sure both the camera and sensor were running the latest firmware. No luck there either.
  3. Third-Party Solutions: I stumbled upon a third-party app that could aggregate video feeds from multiple devices. It wasn’t perfect, but it allowed me to view both the camera and sensor videos in one place.
The Solution:
After some research, I found that the issue was due to the way the Wyze app handles simultaneous motion triggers. To work around this, I set up a routine using IFTTT that automatically moves duplicate videos to a separate folder. This way, I can review them if needed without cluttering my main feed. Additionally, I adjusted the placement of my sensor to avoid overlapping motion detection areas with the camera.
Final Thoughts: While the issue was a bit of a nuisance at first, it’s great to know that with a bit of tweaking and creativity, I could find a workaround that works for me. I’d love to hear if anyone else has encountered similar issues or has other solutions to share!
Cheers,
