I recently installed a Wyze Cam Pan at my weekend home in Vermont, and I thought I’d share my experience and some troubleshooting tips in case others are considering this setup.
The installation process was straightforward, especially since I had an older Foscam camera in the same spot. I used a mount from eBay to secure the Wyze Cam to the window frame and opted for some sturdy screws to ensure it stays put. The wiring was simple—I just fed the cable through the window, which worked well despite the thin cable.
One thing I noticed right away is the excellent night vision when the front light is on. However, in complete darkness without the light, the video quality is quite limited, which was a bit disappointing. Given our rural location with minimal external lighting, I might end up leaving the front light on overnight since it uses LED bulbs and doesn’t consume much energy.
Weather has been a factor, especially with strong winds causing frequent motion alerts. However, the camera held up well, and the video quality remained stable. I’m confident it will handle the harsh winters we experience up here.
For anyone else dealing with motion detection issues, I found that adjusting the sensitivity settings and constraining the motion box to a specific area helped reduce false alerts. Additionally, cleaning the lens regularly is essential to avoid glare and ensure clear footage.
Overall, I’m happy with the Wyze Cam Pan’s performance and would recommend it for outdoor use, especially in sheltered areas. Let me know if you have any questions or tips to share! ![]()
