Hey everyone, I wanted to share a quick tip that might save others some frustration with their Wyze cameras. I recently had an issue with my Wyze Pan camera where the video feed was a bit hazy, making it hard to see details. After doing some research, I decided to take it apart and clean the lens myself. It worked like a charm!
Here’s what I did:
- Power Off and Unplug: Always a good first step to ensure safety.
- Locate the Lens Housing: On the Wyze Pan, it’s a small, circular cover on the front.
- Gently Remove the Cover: I used a plastic pry tool to avoid scratching the housing.
- Clean the Lens: I used a microfiber cloth with a tiny bit of isopropyl alcohol. Be gentle to avoid smudging.
- Reassemble: Carefully put everything back together. No screws were needed, so it snapped right into place.
After this quick fix, the video quality improved significantly! If you’re experiencing similar issues, I highly recommend giving this a try. Just be careful and patient during the teardown process.
Has anyone else had success with cleaning or maintaining their Wyze cameras? I’d love to hear other tips or tricks!
Happy tweaking! ![]()
