Hey everyone, I’ve been experimenting with using my Wyze Cam in the garage to help with parking, and I wanted to share my experience and some tips in case anyone else is looking to do something similar!
The Goal:
I’ve always struggled with parking in my garage—it’s a tight space, and I often end up bumping into things. I thought, why not use my Wyze Cam to help me out? My idea was to set up a motion alert system that would notify me if I was getting too close to the edges of the garage. Basically, I wanted to create a virtual boundary that would alert me if I crossed it while parking.
The Setup:
I started by mounting the Wyze Cam in a corner of the garage where it could get a good view of the entire space. Then, I used the Wyze app to set up a motion zone across the image. The idea was that if motion (like my car) approached that zone, I’d get an alert. It sounds simple, but getting it just right took some tweaking!
Challenges and Solutions:
- False Alerts: At first, I was getting alerts for everything—my cat walking by, the garage door opening, even sunlight hitting the floor at certain times of day. To fix this, I adjusted the sensitivity settings and set up specific times when the alert system would be active (only when I knew I’d be parking).
- Zone Placement: Finding the right spot for the motion zone was tricky. I ended up placing it a bit further back than I initially thought to give myself enough warning without being overly restrictive.
- Integration with Other Devices: I also linked the Wyze Cam with my smart lights. Now, when the alert goes off, my overhead lights flash briefly, giving me a visual cue in addition to the app notification.
Tips for Others:
- Experiment with Placement: Don’t be afraid to move the camera or adjust the motion zone a few times to get it just right.
- Use Custom Alerts: If your camera supports custom alerts, you can set up specific tones or messages that are less jarring than the default notifications.
- Combine with Other Smart Home Features: Like I did with the lights, think about how you can integrate the Wyze Cam with other devices in your home for a more seamless experience.
Final Thoughts:
This project has been a fun way to get more value out of my Wyze Cam, and it’s definitely made parking in my garage less stressful. I’d love to hear if anyone else has tried something similar or has tips for improving this setup!
Cheers,
