Hey everyone, I just wanted to share my experience with the Wyze Cam V2 and see if anyone else has encountered a similar issue. I recently purchased two Wyze Cam V2s, and while one is working perfectly, the other is giving me some trouble. Specifically, it gets stuck at step 3/3 when trying to connect to the stream. I’ve tried updating the firmware a few times, but each attempt fails. I’m starting to wonder if I might have bricked it somehow. The camera is located about 20 feet from my router, and while the signal strength is decent (2 out of 4 bars), I’m not sure if that’s the root cause. I’ve reset the camera multiple times, configured it again, but it still doesn’t connect. I’m planning to move it closer to the router tonight and see if that helps. If not, I’m not sure what else to try. Has anyone else had this problem? Any suggestions would be greatly appreciated! I’m really hoping to get this working since it’s driving me a bit nuts. Thanks in advance for your help!
