Hey everyone, I’ve been using Wyze cameras for a while now, and I wanted to share some tips I’ve picked up during my journey. If you’re like me and have a few Wyze cameras set up around your home, you might have noticed the occasional firmware update. I know, it can be a bit of a hassle, but trust me, keeping your firmware updated is worth it for better performance and security!
One thing I noticed is that sometimes the firmware update process can be a bit finicky, especially if you’re using the latest Xfinity Modem and WiFi router. I upgraded mine recently and ran into some issues where the firmware update kept failing. After some research, I found that the merged 2.4 and 5.0 GHz network settings might be causing the problem. If you’re experiencing the same issue, try checking your router settings to see if separating the bands helps.
Another tip I have is to make sure your cameras are connected to a stable internet connection. I learned this the hard way when my camera lost connection during an update, and it ended up not working properly. Now, I always double-check the internet connection before starting any updates.
I also found that scheduling updates during off-peak hours can make a big difference. That way, you’re less likely to run into connectivity issues, and your cameras can update smoothly without any interruptions.
Lastly, if you’re having trouble with the firmware update, don’t hesitate to reach out to Wyze support. They’ve been really helpful for me, and they usually have a solution or workaround for any issues you might be facing.
So, there you have it! A few tips to help you navigate the sometimes tricky world of Wyze camera firmware updates. I hope these insights help you keep your cameras running like new. If anyone has any additional tips or experiences to share, I’d love to hear them in the comments below!
