I’ve been using Wyze cameras for a while now, and while they’re fantastic, I’ve had some issues with false motion alerts. Specifically, my Wyze Cam v3 kept recognizing tree shadows as vehicles. It was pretty frustrating because the camera is in the center of the area, so I couldn’t utilize the detection zone without making the camera less effective.
After some research and trial and error, I found a few solutions that really helped. First, I adjusted the sensitivity settings in the Wyze app. Lowering the motion sensitivity reduced the number of false alerts, but it was still a bit hit or miss.
Then, I discovered the importance of proper placement. I moved the camera slightly so that it wasn’t directly facing the trees. This helped reduce the shadows in the frame. Additionally, I set up custom alerts for specific areas. Instead of monitoring the entire yard, I focused on the pathways and the driveway where actual movement matters.
Another tip I’d like to share is using the Wyze app’s schedule feature. I programmed the camera to be more active during peak hours when people are likely to be around. This way, it’s less likely to pick up shadows during the early morning or late evening when the sun is low.
If anyone else is struggling with similar issues, I’d recommend experimenting with placement and sensitivity settings. Also, don’t hesitate to reach out to the Wyze support community—they’ve been incredibly helpful with troubleshooting.
I’d love to hear if anyone has other tips or tricks for improving motion detection accuracy. Let’s keep the conversation going and help each other make the most out of our smart home devices!
