Wyze Camera Power Consumption and Battery Life Tips
I’ve been using Wyze cameras for a while now and thought I’d share some insights on their power consumption and how to maximize battery life. While I haven’t tested every model, my experience with the Wyze Cam V3 has been quite positive, especially when it comes to reliability and video quality.
For those considering using a power bank to power their Wyze cameras, I’ve done some rough calculations. A 5000mAh power bank should last anywhere from 2 to 4 weeks, depending on usage. This is based on the camera’s average draw of around 150mAh when actively monitoring. Of course, this can vary if motion detection is frequently triggered or if the camera is used for live streaming.
One tip I’d like to share is to optimize motion settings. Lower sensitivity settings can help reduce unnecessary wake-ups, which in turn conserves battery life. I’ve found that setting the sensitivity to around 30-40% works well for my setup, balancing detection accuracy with battery efficiency.
If you’re using multiple cameras, consider staggering their activation times or setting different schedules to distribute the load. This can prevent a sudden drain on your power source and ensure more consistent performance.
Overall, Wyze cameras are a great value, and with a little tweaking, they can be both reliable and energy-efficient. If anyone has additional tips or experiences to share, I’d love to hear them! Let’s keep the community knowledge flowing. :rocket:
