I’ve been using Wyze cameras for a while now, and I must say, they’ve been a great addition to my smart home setup. However, I recently stumbled upon an issue that had me a bit puzzled. Let me share my experience in case it helps others facing the same problem.### The ProblemMy wife and I have been using Wyze cameras to keep an eye on our home. Everything was working smoothly until I noticed that the thumbnail view wasn’t showing any events, even when the SD card icon was flashing. The message “No Events in the Last 24 Hours” kept appearing, which was frustrating because I knew the cameras were detecting motion.### My InvestigationI started by checking the Wyze app version on both my wife’s and my devices. We were running version v2.47.0 (373) on an Android 13 UI 5.1. I did a quick search on the forums and found a few posts mentioning similar issues. It seemed like this wasn’t an isolated problem, but rather a bug that had affected several users.### The SolutionAfter some research, I discovered that updating the Wyze app to the latest version often resolves such issues. I decided to give it a shot. Here’s what I did:1. Uninstall the Current App: I uninstalled the existing Wyze app from both our devices to ensure a clean install.2. Reinstall the Latest Version: I downloaded the latest version of the Wyze app from the Google Play Store.3. Reconnect Cameras: After reinstalling, I reconnected all our cameras to the app.### The OutcomeTo my delight, the thumbnail view started working perfectly again! The app now correctly displayed the events, and the SD card icon no longer showed the “No Events” message. It was a simple fix, but it made a world of difference.### A Word of CautionIf you’re experiencing similar issues, I recommend checking for updates regularly. Sometimes, bugs like this are quickly patched in newer app versions. Also, ensure that your devices are running the latest firmware to avoid compatibility issues.### Final ThoughtsWhile encountering bugs can be frustrating, it’s reassuring to know that the Wyze community is active and supportive. If you’re facing any issues, don’t hesitate to reach out on the forums. Chances are, someone else has encountered the same problem and found a solution.Happy smart home monitoring everyone! ![]()
