Hey everyone, I wanted to share my positive experience with the Wyze Robot Vacuum after struggling with the under-bed cleaning issue. I’ve been using my Wyze Robot Vacuum for a few months now, and while it’s been a great addition to my cleaning routine, I was initially disappointed that it couldn’t clean under my bed. The bed skirt was always detected as a wall, and the vacuum would shy away, leaving that area untouched. Cleaning under the bed was one of the main reasons I purchased the robot vacuum, so this was a bit frustrating.After some research and experimentation, I found a simple workaround. I decided to lift the bed skirt slightly by tucking it up out of the way. This small adjustment allowed the vacuum to glide under the bed without any issues. It wasn’t a perfect solution, but it got the job done without too much hassle. I was pleasantly surprised at how effective this simple fix was.Recently, I noticed that my Wyze Robot Vacuum seemed to be navigating under the bed more confidently. I realized that there had been a firmware update, and I suspect that this update improved the vacuum’s ability to distinguish between hard walls and softer obstacles like bed skirts. Now, I can clean under the bed without having to adjust the bed skirt every time. It’s a small improvement, but it makes a big difference in the vacuum’s functionality.I’m really happy with how this situation turned out. The initial frustration was worth it, especially after finding a workaround and seeing the improvement with the firmware update. If you’re considering a robot vacuum, I’d definitely recommend giving the Wyze Robot Vacuum a try. It’s affordable, reliable, and with a little creativity, it can handle even those tricky under-bed areas.Looking forward to future updates and improvements! ![]()
