Hello everyone, I’m currently working on integrating my Aeotec Z-Stick Gen5 with OpenHAB. I’ve successfully paired two Fibaro sensors using the Aeotec IMA tool, and they seem to be communicating fine. However, when I check HABmin, I don’t see any devices listed under the Z-Wave Bindings. I’ve followed the configuration steps, including setting the correct port in openhab.cfg and adding the necessary user permissions. My items file is set up with the appropriate Number types for Movement, Alarm, Lux, Battery, and Temperature, all linked to the Z-Wave binding. I’ve also restarted OpenHAB multiple times. Despite all this, the devices still don’t appear. I’m wondering if there’s something I’m missing in the configuration or if there’s a known issue with the Z-Stick Gen5 and OpenHAB compatibility. Any advice or suggestions would be greatly appreciated! Thanks in advance for your help.
