Hey everyone! I just wanted to share a fascinating experience I had with my Raspberry Pi setup. I’ve been using a PI2 with a Razberry board for Z-Wave integration, housed in a clear plastic box, and it worked pretty well. However, when I upgraded to a PI3 and placed the same Razberry board in a black plastic enclosure, I noticed some real reliability issues with my Z-Wave signals. The system was acting up, devices weren’t responding as they should, and it was quite frustrating.
After some troubleshooting, I realized the problem might be with the enclosure itself. I decided to take off the lid of the black box, and voilà! Everything started working perfectly again. It turns out the enclosure was interfering with the Z-Wave signal, which I hadn’t even considered at first. This was a bit of a revelation for me and taught me to always check the physical setup when encountering connectivity issues.
If you’re experiencing similar problems with your Z-Wave devices, I’d suggest taking a look at your Raspberry Pi enclosure. Maybe a simple adjustment like removing the lid could make a world of difference. It’s always good to remember that sometimes the solution is right in front of you, even if it’s not immediately obvious!
I’d love to hear if anyone else has had similar experiences or found other creative solutions to Z-Wave signal issues. Let’s keep the conversation going and help each other out with these smart home setups! ![]()
