I would like to know if anyone had success to use the Long Press button function for automation on the Z1 Pro Switches.
The device should support the long press function. Could anyone share an example or maybe a screenshot showing how you set it up or how it appears in your app/automation?
Is yours the 4 button version?
If not you can only set long press on the sliding area, not the buttons.
If yours is the 4 button version, I think you have to set the last button as a multifunction button to enable long press.
does this mean the double click function is also only working for the slider?
Yes. Single click, double click and long press refers to the sliding area, although they are more of a tap than click (lost in translation I guess).
