Zigbee Multisensor with Light Level Detection: A Comprehensive Guide
I’ve been exploring the world of smart home automation, and one device that has truly impressed me is the SmartenIt 1019C Zigbee Multisensor. This device combines motion detection, light level sensing, and temperature monitoring, making it a versatile addition to any smart home setup. While it’s not the most feature-rich device on the market, it’s definitely a solid choice for basic automation needs.
Why I Chose This Device
I wanted a motion sensor that could turn on lights only when it’s dark outside. After some research, the SmartenIt 1019C stood out because it supports Zigbee Home Automation, which is compatible with platforms like SmartThings. Plus, it’s certified for global Zigbee standards, so frequency issues aren’t a concern for me in Australia.
Setup and Configuration
Setting up the sensor was straightforward. I used a Conbee II stick to integrate it into my Zigbee network, and it paired without any hiccups. The sensor is battery-powered, so I made sure to use high-quality rechargeable batteries to ensure longevity. I went with Panasonic Eneloop 1900mAh batteries, as they fit perfectly and last a long time.
For configuration, I relied on the Zigbee2MQTT integration in Home Assistant. While there isn’t a dedicated device type for this sensor, the default Zigbee Home Automation profile worked well for my use case. I set up a simple automation in Home Assistant to turn on my hallway lights when motion is detected and the light level drops below a certain threshold.
Real-World Use Case
Here’s how it works in my home:
  • Motion Detection: The sensor detects motion reliably, even in low-light conditions.
  • Light Level Trigger: The lights only turn on when the ambient light drops below 50 lux, ensuring they don’t activate during the day.
  • Automation: The lights stay on for 15 minutes before turning off automatically. This is perfect for late-night trips to the bathroom or quick hallway movements.
Tips for First-Time Users
  1. Battery Management: Invest in high-quality rechargeable batteries. I’ve tried several brands, but Panasonic Eneloop and Energizer Recharge have been the most reliable.
  2. Firmware Updates: Keep an eye out for firmware updates for your Zigbee stick and the sensor itself. Updates often improve compatibility and performance.
  3. Integration: If you’re using Home Assistant, the Zigbee2MQTT integration is a great way to get started. It provides detailed sensor data and allows for custom automation rules.
Conclusion
While the SmartenIt 1019C might not have all the bells and whistles of higher-end sensors, it’s a cost-effective and reliable solution for basic automation needs. Its compatibility with Zigbee and support for light level detection make it a great choice for anyone looking to enhance their home’s security and convenience without breaking the bank.
If you’re considering this sensor or have questions about its setup, feel free to reach out! I’d love to help you get started on your smart home journey. :rocket:
