Hello everyone, I’m relatively new to the world of Zigbee and have been trying to set up my network with a CC2531 dongle and some Aqara sensors. I’ve encountered a few challenges that I’m hoping the community can help me with.
First, I’ve been struggling with getting my Aqara temperature and humidity sensor to pair properly. I’ve followed the instructions to flash the dongle and add the sensor, but I keep running into an error with the ZToolPacket type 0x45cb. I’ve checked the logs and see that the sensor is detected, but it doesn’t seem to establish a stable connection. Has anyone else experienced this issue, and if so, how did you resolve it?
Additionally, I’ve noticed that my system time seems to be set to UTC after a recent firmware update. This has caused some of my routines to run at the wrong times, which is quite frustrating. I’ve tried changing my location settings to adjust for this, but it’s a bit of a workaround. I’m curious if others have faced this problem and if there’s a more permanent solution.
I really appreciate the support and knowledge-sharing within this community. It’s been a great resource as I navigate setting up my smart home. I’m hopeful that with some guidance, I can get my Zigbee network up and running smoothly and resolve the time setting issue once and for all.
Thanks in advance for any advice or insights you can share!
