I’ve been diving into the world of Zigbee2Mqtt lately, and I wanted to share my experience in case it helps anyone else who’s going through the same process. Setting up Zigbee devices can be a bit overwhelming at first, but with the right approach, it’s totally manageable!
First, I started by installing the Zigbee2Mqtt addon along with Mosquitto broker on my Home Assistant setup. I chose the SONOFF Zigbee Gateway, ZBDongle-E 3.0 as my gateway. The installation went smoothly, but I ran into an issue where my devices weren’t showing up correctly in Home Assistant. Specifically, I added a Miboxer FUT035Z CCT Dimmer, but only the “Do not disturb” and “Effect” entities appeared—nothing for turning the light on or adjusting the brightness.
After some research, I realized the problem might be with the firmware on my Zigbee devices. I checked the Zigbee2Mqtt documentation and found that some devices require specific firmware versions to work properly. I updated my gateway firmware and also made sure all my devices were on the latest firmware. This made a huge difference!
Another tip I picked up was to carefully review the logs in Home Assistant. They can be a bit cryptic at first, but they often give clues about what’s going wrong. I also found that resetting the Zigbee network and重新 pairing devices one by one can help if things get messy.
If you’re just starting out with Zigbee2Mqtt, here are a few things to keep in mind:
- Check Firmware Versions: Make sure both your gateway and devices are up to date.
- Use the Right Gateway: Not all gateways are created equal. Do some research to find one that’s well-supported.
- Review Logs: They’re your best friend when troubleshooting.
- Be Patient: It might take a bit of trial and error, but it’s worth it in the end!
If anyone has specific questions or issues, feel free to ask. I’m happy to share what I’ve learned along the way! ![]()
