Let’s get started. First of all, set the W100 to the data transmission mode for 10 minutes with ∆2°C. W100 Explanation of the temperature sampling setting для то Second, the T1 sensor for temperature control is very inertial, it sends a signal once an hour or when the temperature changes by 0.5°C, so there may be temperature jumps in the room. For example, the temperature is 22°C and the sensor will send data only when it is 22.5°C.
Are these automations for one air conditioner or two different ones?
