Aqara temperature sensor
What is the problem that the Aqara W100 sensor is updated with data 17 hours ago?
I have 3 other T1 sensors, which work normally. I have been using these sensors for 1 week, so after 1 week there are problems with the W100.
The W100 is in close proximity to the HUB M3.
I have everything connected to the HUB M3
I see that the W100 cannot be reset remotely, so do I have to reset it manually? I reset the M3 and it didn’t help.
I bought the W100 mainly because it has a screen.
Hi, take a look here, maybe it will help.
No settings, now showing data.
Missing data from 5pm tonight to 2pm today.
I don’t have this Temp Humidity Sampling Setting option in my menu
Do you have the ability to connect via Zigbee?
I think there was option to Zigbee connect. Maybe this connection be better than Thread
Obviously, there are more settings in Zigbee mode. Remove W100 and reconnect to Zigbee mode.
